Rear Brake flush, now brakes do not work
Old 04-27-2006, 05:35 AM
Daredevil's Avatar
Default Rear Brake flush, now brakes do not work
i have a 98 f3
front brakes are great
went to do a brake flush on the rear, used dot 4 brake fluid. (same stuff i used in my track car, AP Racing) i figured it wouldn't make a difference.
got all the air out, but now my rear brake sucks *****
is there some sort of trick to this?
thanks
Old 04-27-2006, 01:07 PM
denhou1974's Avatar
Default RE: Rear Brake flush, now brakes do not work
DOT 4 is the recommended fluid.
What makes it suck? Does it feel soft or spongy? Does it fade?
Old 04-27-2006, 03:43 PM
Daredevil's Avatar
i have dot 4 fluid
before i changed it, i could lock up my rear tire, and it had a lot more stopping power
now that I changed it, the pedal is hard, but it just doesn't come to a stop, well it does, hardly at all. i can press down as hard as i can, and still nothing happens
Old 04-27-2006, 06:59 PM
Did you replace the pads or get any brake fluid on the pads that were on it? I just put new pads on my bike and I didn't think it was going to stop at all. After riding the rear brakes for awhile they started working great.
Old 04-28-2006, 08:37 PM
You still have air in the line. The higher you get the rear when you bleed them the better.
Full_Throttle
F2 Tech
03-09-2012 08:04 AM
phillycbr
09-02-2009 10:35 PM
Bobbo
06-28-2008 05:50 PM
FLYOU
07-13-2007 08:12 PM
RandomStrata
03-06-2006 07:06 PM
Quick Reply: Rear Brake flush, now brakes do not work
