Raising my bike back up?
Old 07-08-2009, 08:52 AM
johnnyx's Avatar
Originally Posted by liquid_insanity
Also, check if the kickstand was shortened, I can't see if it has been or not.
It looks to me like the kickstand was bent forward to accomodate for the lower bike height. It's supposed to be straight, not curved like that, and the flat plate on the bottom is supposed to be flush with the ground, I can see it sticking up at damn near 45 degrees. Don't put that thing on any soft asphalt. You can probably heat it up and bend it back, but I don't know if I'd trust it.
Given that the PO did such a ghetto mod on a cheap part, I'd give the whole bike a once-over if I were you.
Old 07-09-2009, 11:51 PM
Kuroshio's Avatar
Ok, received the stock dogbone from ebay in the mail today (not ready to install it till I can safely jack the bike up). So I'm set there.
I'm wondering about the front height tho. How would I be able to tell how much the front was lowered? And how would I know when I've reached stock height in the front? I doubt the PO paid to have the suspension altered so I'm betting they slid the forks up. So how much should I slide them back down?
Old 07-10-2009, 03:13 AM
Trunk-F3's Avatar
Ive seen this done once before and the first thing you should do is to make sure that the bike is jacked up and secure from falling. My buddy just loosened up the clip ons and slid them up to about an 1/8" below the little snap ring thing on the top of the forks and then snugged them back up. Then he just loosened up the pinch bolts on the triple trees, made sure they were snug against the clip ons and voila, unlowered. Hope that makes sense or helps
Ordie
01-29-2015 02:24 PM
FosmoenAlex
03-10-2008 04:07 PM
haak30
06-11-2007 01:14 AM
Stitches
04-12-2007 07:25 PM
20F4i02
04-25-2005 02:24 AM
Quick Reply: Raising my bike back up?
