Problem with throttle bar end binding..
Old Oct 14, 2009 | 05:36 PM
blakesgst's Avatar
Default Problem with throttle bar end binding..
My bike is finally done except for this one last issue! I installed my bar ends today and the darn throttle one binds up and causes the throttle to stick. If i push the grip to the left it binds on the switch box. Just curious if this is common? Should i just cut a bit of the end of the grip off on the throttle side? The grips are the original ones that came with the bike so nothing strange there.
Blake
Old Oct 15, 2009 | 06:40 AM
Northernfirepower's Avatar
Yeah, it's not pretty but I did cut my throttle one down too. Still not sure why it does that ... I believe the bar end mount is glued in place so there was no hope moving that, at least for me.
Old Oct 15, 2009 | 11:47 AM
blakesgst's Avatar
Thanks Northern, i figured that was the answer but that sure is annoying! I'll have to keep my eye out for grips, see if maybe some might be a bit shorter than others.
Blake
Old Oct 15, 2009 | 12:03 PM
abeer1's Avatar
Just cut down the grip a little bit and that should resolve the issue.
Jeffcbr600f2
Apr 21, 2014 09:18 AM
jdub22
F2 Tech
May 22, 2011 08:49 PM
blakesgst
Oct 2, 2009 05:48 PM
ceracer33
Jul 21, 2008 11:08 PM
leonaro111
May 19, 2005 02:04 AM
