oil pressure?
You could install the sending unit in place of where the Oil Pressure Switch is. It's below the Right Crankcase cover with a black rubber cover over it. Not sure what fittings you might need, or where you'd mount the guage itself, but that's where you should put it.
yea i got some fittings from homedeopt i got a spacer threaded it directly to the case then a t fitting mounted the low pressure switch behing it and the pressure line infront then ran the line to the guage. hooke it all up worked great. except the light was white as we know the guage lights are green. so i took a trip to advanced auto and bought s et of green led lights, there little accent lights. i mounted one of them in place of gthe stoick guage bulb and it looks great. thanks for the help.
Jeff
Jeff
