oil change question
Old Sep 28, 2006 | 08:21 AM
jayson_219's Avatar
Default oil change question
i just changed my oil the other day. i had a couple questions about the oil filter. i was looking at the manual and noticed that there is an O ring that comes off the original oil filter. when i changed my oil filter i didnt pay attention to whether or not the new filter had a O ring in it. do new oil filters come with O rings in them? or did i just F up and throw the O ring away with the used oil filter. another question is i notices my bike would start smoking a little bit after about 10 minutes of riding. im assuming this is the oil that i spilled while removing the original oil filter. is my asumtion wrong? i sure hope not. let me know what you guys think.
Old Sep 28, 2006 | 08:50 AM
gerharddvs's Avatar
Default RE: oil change question
When I replaced my oil filter its was like the one’s used on cars in the aspect that the rubber is part of the filter or stuck on to it. It didn’t come separate. So if there’s no oil leaking from where it fits, I wouldn’t worry (It’s sealing)
In terms of the smoking problem. If the bike wasn’t smoking before you changed the oil, it could be:
You are using the wrong grade of oil (it could be too thin)
You just put to much oil. The oil then pushes thru the breather into the carbs hence you burn oil. If it’s not to much I’d just drive it till the access oil has burnt away but if it’s a lot it’s better to drain some of it
Old Sep 28, 2006 | 10:40 AM
jarhead's Avatar
The new filter has the o ring on it. As far as the smoking goes it is probably just a little oil that spilled on the headers it will burn off after your first ride.
Old Sep 29, 2006 | 06:15 AM
jayson_219's Avatar
cool thanks guys, thats what i was hoping to hear. im gonna ride it for a while and see if the smoke goes away. if not ill have to drain some of that new oil out. thanks
VP
Jan 8, 2009 09:14 PM
itgbudeev
Jun 3, 2008 04:35 PM
hoopster3
Mar 18, 2008 05:59 PM
600f2supersport
Mar 8, 2008 12:54 PM
gunrman13
Jul 8, 2005 02:22 PM
