odometer and trip not working
Old Apr 11, 2011 | 11:00 PM
sony224422's Avatar
Default odometer and trip not working
When i got the bike, the seller was honest and told me the cluster didn't work with tach (broken needle after a fall) and the odo didn't work. It has a newer engine in it, and it runs well, so i bought another cluster to fix this, and the odometer still doesn't work.. and neither does the trip one. What controls this? every other gauge and light works. The new cluster i put on was in storage for years, and only has 3999 miles on it
Old Apr 23, 2011 | 02:58 PM
sony224422's Avatar
anyone? maybe the speed sensor is going out?
Old Apr 23, 2011 | 04:46 PM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
did you trace the wire harness and make sure everything is plugged in correctly to the engine?
Old Apr 24, 2011 | 09:38 AM
The speed sensor is located on top of the rear portion of the engine above the output shaft for the front sprocket. The connector is a 3 pin white connector near the right engine hanger bracket. Try unplugging and replugging this connector. If you've got a meter, you can check for battery voltage on the Green/Black wire to the Black/Brown wires. If you have voltage there, then there is another test you can do on the gauge cluster. Lets start with the simple things first, check the connector. You can see it here above the Thermostat housing.
Old May 3, 2011 | 09:33 PM
sony224422's Avatar
thank you for the picture.. it is not that. i replaced the speed sensor today.. no luck. i must have a bad cluster again as my speedo stopped working too. it will only randomly work.. i checked the wires on the back and its all plugged in. i don't know what im missing. although my rectifier was toast so i wonder if it blew out stuff
Old May 3, 2011 | 11:00 PM
Get the manual and perform the checks that are in there for the odometer. This way there won't be any guessing.
oopssorry13
Jan 14, 2015 01:24 PM
hikeetech
Aug 26, 2011 01:46 PM
shleeve
Aug 28, 2010 07:18 PM
94F2CBR
Sep 13, 2007 08:20 PM
buddah
Aug 1, 2007 06:52 PM
