Not starting
Old Jul 21, 2007 | 06:30 PM
Lvpunnk's Avatar
Default Not starting
Hi all, I'm trying to start my bike whichI do at leastonce a week until I take my MSF class and can actually ride it. Today I tried to start it and it cranked a little bit, but then the starter would just start clicking, is this a starter or a battery issue and is it possible to kick start a bike like you would a car on a hill or something?
Thanks,
Jeff
Old Jul 21, 2007 | 06:50 PM
MikeInCtown's Avatar
Default RE: Not starting
The battery was probably too low. Try charging the battery. and yes, you should be able to start the bike on a hill like you would with a car.
Old Jul 21, 2007 | 07:21 PM
Lvpunnk's Avatar
Thanks Mike, charging now.
Old Jul 21, 2007 | 07:30 PM
zerokreativity's Avatar
Why are you starting it if you aren't riding?
Old Jul 21, 2007 | 07:39 PM
Lvpunnk's Avatar
Mostly because I can't help myself. It's rough.
Old Jul 21, 2007 | 07:50 PM
Can't say that I blame you.
The bike will start on a hill, I've done it a lot in the past.
If you are going to start it just for the sake of hearing the engine be sure to run it for a little while so that the engine recharges the battery enough each time.
Old Jul 21, 2007 | 07:52 PM
Lvpunnk's Avatar
Will do, thanks.
Old Jul 21, 2007 | 08:30 PM
Tweaker600's Avatar
Yea, my bike was doing the same thing. Would be able to start then after a few times it just wouldnt be able to start. I got a trickle charger and it helps a lot. I heard that the headlight was draining the battery. But i need to figure all that out cause my bike still is dying. But hope everything works out for you
Old Jul 21, 2007 | 09:15 PM
Lvpunnk's Avatar
Thanks, yeah I charged it with an all purpose charger and it started right up better than ever, it was a huge pain to get to the battery and pull it out and put everything back together though.
BlackDogIron
Sep 14, 2017 05:47 PM
Nevets
Nov 8, 2010 04:45 PM
BrokeCollarBone
Nov 24, 2009 01:24 PM
bh1
Dec 7, 2007 02:36 PM
steeper
Jun 23, 2006 02:49 PM
