NOOB question.
Old Feb 22, 2009 | 08:32 PM
sonofapplepm's Avatar
Default NOOB question.
Just bought 95 f3 with 34,xxx miles. There is a ticking noise coming from the front right side of the engine that comes and goes at different rpms. My question is, What could be the cause?
Thanks, Josh
Old Feb 22, 2009 | 08:47 PM
MrBomb's Avatar
i would say thats a cam chain tensioner problem,
its a easy fix just 2 bolts to take off and on, however im no expert on this yet so wait for others to chime in but thats what i would say
Old Feb 22, 2009 | 09:07 PM
Thanks, MrBomb! I appreciate the reply. I'll take your advice and get a few more replies. I was guessing that could be the noise, but want to confirm it!
Thanks again, Josh
Old Feb 23, 2009 | 09:30 PM
Speedemon636's Avatar
Might possibly be one of the rod bearings saying "i'm worn, change me!" lol but hopefully it is just the cam chain tensioner. I had a knock on my Ninja 250 and it was rod bearings.. I dunno. Try cam chain first. Much less work to check that than rod bearings lol. Good luck!
Old Feb 23, 2009 | 09:45 PM
jalen11598's Avatar
From what you described and where the sound is coming from, it do sound as if your cam chain tensioner has gone bad. Like MrBomb said, it is a really easy fix. I would recommend an after market manual adjusting one. You can find them on ebay.
Old Feb 24, 2009 | 06:10 PM
Thanks for the replies! Seems to be a friendly bunch around here!
Thanks again, Josh
Old Mar 3, 2009 | 12:12 PM
kjohnson's Avatar
Manual CCT is the way to go.50 bucks,two bolts and a 1/2 hour labor and you're rockin
Old Mar 3, 2009 | 04:08 PM
Thanks, got an A.P.E manual cct on the way!
Josh
Old Mar 3, 2009 | 07:07 PM
People talk about a manual CCT, but take a look at how well the factory automatic one did. 34,000 miles and 14 years. I'd bet that it's the original CCT on your motor. The automatic tensioner never required anyone to adjust it in 14 years. You're replacing it with one that every so often, you'll have to check it, or at least think about it.
IMO for what it's worth.
Old Mar 4, 2009 | 11:58 AM
kjohnson's Avatar
The OEM ones are hydraulic and bleed down over time.This is how all oem's are (Yammy,Suzi,Kawi,etc etc).The manual one you can adjust,the oem one you cannot.Manual one is the way to go.
Mario072
Jul 29, 2011 04:57 PM
CBRockin
Dec 22, 2010 08:06 PM
S2005
Jun 11, 2010 08:59 PM
Vanandt71
Jul 29, 2009 07:40 PM
jersey8
Dec 16, 2007 11:19 AM
