No Start
Old May 11, 2011 | 07:05 PM
89cb1's Avatar
Default No Start
So my 1995 f3 just stopped running yesterday. I havent driven it on the streets yet but just had a bunch of work done to it and it was running perfect, now wont start. I just had it jetted and installed an ape tensioner. I checked for fuel and spark both are good and removed the fuel pump and tested it properly and it works great. It cranks and will sputter a couple time but wont fire. I was wondering maybe the kill switch? How does it work, does it kill the spark? Any help would be greatly appreciated.
Old May 12, 2011 | 08:14 AM
fordfenatic09's Avatar
good place to check is your inline fuel filter, it might not be getting enough fuel.
Old May 12, 2011 | 08:32 AM
derekvercher's Avatar
I would change the plugs completely. If you just got it jetted they might have fouled out. It's real common on f3 if you start it rev up a couple times and shut it off. You know like if you just start of for someone to hear it or what ever. You need to let it run a minute or two before shutting it off.
Old May 12, 2011 | 09:45 AM
89cb1's Avatar
The plugs are brand new and everytime I started it I would let it run. The only time I didn't was the last time before it wouldn't start. I ran it for only about a minut or so and then put it away and forgot the choke fully on. But after it wouldn't start the next day I took them out blew out the cylinders and checked for spark on all four.
Old May 12, 2011 | 09:58 AM
I have fouled out a brand new set of plugs on mine. I mean brand new. Second start rev up then shut off and they fouled. I still think its your plugs.
Old May 12, 2011 | 11:25 AM
I agree, mine will do the same thing every once in a while if you don't let it run long enough to get the cylinder temps up enough for a complete burn.
Old May 12, 2011 | 12:24 PM
89cb1's Avatar
I got my last ones from my local honda dealer. Should I get them from there again?
Old May 12, 2011 | 01:28 PM
No they cost too much at Honda. Go to auto store they are like 2 to 3 bucks cheaper per plug.
Old May 15, 2011 | 09:58 PM
89cb1's Avatar
So I installed the new plugs and it runs great! Thanks so much. Saved me lots of time and frustration.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
