No fuel pump 95 cbr600
Old Oct 11, 2012 | 07:17 PM
Moze88's Avatar
New Member
Default No fuel pump 95 cbr600
I am new to this. I just bought my first bike 95 cbr 600 f3. The guy said all the maintanace is up to date. The bike starts ad runs good. It doesn't have a fuel pump and I was told that wouldnt cause any harm. Should I go ahead and look for a new pump? Or just enjoy the bike for a while before putting any more money into it. I paid 1100 for the bike. Was that a decent deal? Thanks in advance.
Old Oct 12, 2012 | 03:47 AM
vfrman's Avatar
Party Animal, ROTM June 2014
I would ride the bike. If you are getting fuel starvation at high rpms, put the pump in.
Old Oct 12, 2012 | 06:07 AM
turbotodd3023's Avatar
New Member
I would check and make sure whoever said it didn't have a fuel pump actually know what they were talking about.
Check left side under seat. Sounds strange anyone would remove it but people are strange...
I am a firm believer in "if it ain't broke don't fix it.
Old Oct 12, 2012 | 07:59 AM
Sprock's Avatar
Gravity feeding the carbs is never really a big issue and getting rid of the fuel pump
eliminates a fairly common point of failure -since the bike runs good leave it alone
Welcome to the Forum btw - the F3 section has plenty of good people with specific
advice
Old Oct 12, 2012 | 08:50 AM
Moze88's Avatar
New Member
Thanks for the info. Sorry if I posted in the wrong spot I am just learning how this all works. Ill leave it as is until I come across any issues.
Old Dec 3, 2012 | 11:20 AM
Wrecker's Avatar
Registered Users
You may have vaccume/gravity issues under a certain point 1/2 tank ? Dont be supprised if you run out with a bit of gas left
Old Jan 14, 2018 | 01:09 AM
HAndHEldJEsuS's Avatar
Sorry I have a f3 so I’m not sure about the f1 sorry about that!!!
Old Jan 14, 2018 | 05:32 PM
Gunk's Avatar
The early CBR900RR’s will function fine with the pump removed, the 600 however relies on the pump to deliver fuel at higher revs and to start the bike, I would personally retain the pump.
Old Jan 24, 2018 | 05:34 AM
BwanaTumbo's Avatar
I have a 98 CBR600F3 and at the moment it is without fuel pump..... was eliminating a start problem and just haven't put the pump back on. Your bike will start and run without the fuel pump, however as Wrecker says you will have problems on a low tank. Also above 120 mph your carbs will dry up faster than they can be gravity fed......... I found out last night :-). You will also have to switch the tap to reserve and not forget to switch it to off when parked up. Id suggest you put one back on ...£20 on fleebay for an aftermarket one. I will also be adding a gravity fed pipe link to my break down kit under the seat in case the pump goes while out and about.
Kopi Ko
Sep 6, 2024 12:02 AM
building
Oct 21, 2010 05:43 AM
shok47
Oct 10, 2010 08:37 PM
zblad
Dec 5, 2008 01:14 AM
