New member with fuel question
Old 08-17-2010 | 09:38 AM
dcaldwell's Avatar
i also fill up around 120 miles. i ride about 100 miles a day to and from work..well i did when she was running anyways . i dont run her very hard and ill get upwards of 48 mpg. however, im pretty sure i dont have the stock 4.5 US gal tank, otherwise, i would fill up every 150-175..
Old 08-17-2010 | 02:23 PM
96@cbr's Avatar
my tank is only like 3.3 or so
Old 08-17-2010 | 08:11 PM
VALKYIE's Avatar
I have used bike bandit for a long time. Parts seem to priced pretty decent. A brand new fuel pump will give you good piece of mind while you are riding down the road and it is worth every penny.
Old 08-18-2010 | 01:26 AM
96@cbr's Avatar
yeah i understand.. but the switch is what goes wrong with them and its easy to fix
Old 10-05-2010 | 07:36 PM
MZ5's Avatar
MZ5
Originally Posted by Cinderfella
Are you running with the petcock in the on position (down) or the reserve (up)?
I've been curious about this, too. Just found the petcock this evening. I can't see in there very well, so: Does the arrow point 'away' from the end of the petcock you hand on to, or does it point 'toward' it? IOW, the 'handle' on my bike's petcock is down. Is that on or reserve? Thanks.
Old 10-05-2010 | 07:53 PM
MZ5's Avatar
MZ5
Never mind. Just found threads saying that my F4 doesn't have 'reserve.' Just 'on,' 'off,' and 'on.' Hope my fuel light works...
Old 10-06-2010 | 12:18 AM
F3LUV's Avatar
Originally Posted by 96@cbr
wow whats up with all the fuel questions this week lol. ive had my fair share lol. i would replace the pump or... look up idodirt and look at his thread and vid about fixing your fuel pump. im in the process of fixing it right now. it seems the contacts on the switch that is located on top of fuel pump wear out causing you fuel pump to malfunction.
i agree. tons a fuel ?'s lately. i agree with the rest of the crew. throw a fuel pump in it. u may get the bike to run good with gravity feed at lower rpm's but these bikes tend to break up under heavy accel or high rpm when they r gravity fed
Old 10-06-2010 | 01:43 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
Originally Posted by Kuroshio
Hey, welcome aboard!
F3's were not designed to run without a fuel pump. People generally do this to bypass a busted fuel pump. And while it may seem to work, it really doesn't. You'll have flat spots where the fuel pump should have kicked in to keep the floats full. And I'm afraid the best diagnostic we can give you is:
Go buy a working fuel pump
+1
So many kids call bs on that statement but kuro is 100% on that. The f2 doesnt have a fuel pump, but the f3 does, and trust me, if Honda put it on there, it's needed.
I've run with and without and I am proof that the fuel pump is needed.
Kuro is on the money on that one.
Old 10-06-2010 | 08:01 PM
kjohnson's Avatar
The ram air is why you need a fuel pump.The pump only provides about 3-4 psi,but as Kiro said,the carb bowls will run dry if you don't have one.
Install a fuel pump,look after the points,keep on rollin'.
odano1988
09-15-2015 08:26 AM
tamahda
10-19-2013 04:39 PM
silverback
05-13-2008 04:18 AM
cronos22
10-09-2006 02:37 PM
kamkind803
03-10-2006 01:56 PM
Quick Reply: New member with fuel question
