Need help, can't get motorcycle started or to stay running
Old May 20, 2024 | 04:07 PM
RA060824's Avatar
Default Need help, can't get motorcycle started or to stay running
Hi, I am new to the forum but have used it in the past for help when people had similar problems but this time I am at a loss and can't find anything. I have a 1998 Honda CBR600F3 and I got it out of storage around the end of April for the season. However, when I tried to start the bike after charging the battery I started to experience issues with it not starting it would sound like it was trying to start, then after a little bit gas started leaking out towards the front of the bike and it looked like it was coming out of the air duct. I eventually got the bike running but it didn't sound like it was running right and it wouldn't go over 4,000 rpm and the bike slowly died, after it shut off the bike wouldn't start again. My dad and I both checked the carburetor and it all seemed fine, I replaced the spark plugs in it, checked the ignition coils and there is a spark, and the first cylinder was flooded, and found gas mixed with the oil. When trying to test the spark plugs more with it all torn apart there is a very faint spark between the end of it and the plug itself, these are from a brand I don't usually use, but I am planning to get new spark plugs again next week of the brand I usually use. I am starting to feel at a loss for what it could be, any ideas or other things to check would be appreciated. Thank you
Old May 20, 2024 | 06:59 PM
rockpool's Avatar
"the carburetor"? - there are four of them. Most likely the idle jets are blocked.
Test with the correct plugs, change the oil, either clean the carbs properly or run a can of seafoam through the bike.
Old May 20, 2024 | 11:28 PM
dannoxyz's Avatar
That will never work. Carbs don’t need “cleaning”, they need “restoration”. Meaning complete disassembly to every last nut, bolt & individual component. Many expert mechanics have had to pull carbs 4-5x for ever deeper cleaning before they were restored back to factory-fresh clean OEM condition.
1. completely disassemble carbs to every last nut, bolt and individual component. If it can be further taken apart, do it. Take lots of photos and videos so you can put it back together properly. Compare to factory service-manual, just in case previous owners modified anything. Needle jets upside down is common mistake. For differentmodel, but yours should be similar with double number of carbs & parts that needs to be completely disassembled.
2. Completely disassemble emulsion-tube and pilot jet.
3. clean out all secret hidden passages in carb-body with PEA-based fuel-system cleaner and
<b>scrub brushes</b> scrub brushes
. Note: spray “carb-cleaners” no longer work due to removal of chlorinated compounds. Thanks a lot crunchy-granola, tree-hugging, bark-eating smelly hippies! For different model, but yours will be similar:
4. Poke out all lateral bleed holes with soft copper wire. Dried petrol turns to plastic and cannot be dissolved again. Must be mechanically scrubbed away. Also poke out all bleed-holes in carb-venturi towards float-bowl.
5. Ultrasonic soak everything for days. Micro soda-blast everything before reassembly.
6. Replace all rubbers: float-valves, pilot-screw O-rings, fuel-rail O-rings, float-bowl seals, slide-diaphragms if needed.
7. Set float-levels to stock. Verify with external wet-test when back on bike. 8. Do rough bench-sync. Then fine-tune with manometers
If you skipped any if these steps, that’s why bike isn’t running right. When carbs are restored back to factory-fresh clean, it’ll run like brand-new off showroom floor. That kind of restoration requires lots of specialised equipment and decades of experience on hundreds of sets of carbs and even destroying some in process of learning. Best to send to pros for expert restoration, reasonable fees and quick turnaround.
https://customcarbservices.com
Old May 21, 2024 | 08:11 AM
rockpool's Avatar
Originally Posted by Sampledwharf
I will check the idle jets next, the plugs I used are correct, just a different brand but I plan to get the brand I typically use next week, as for an oil change, I plan to once I get the bike running, and I tried a bit of B12 first with no luck and then tried seafoam but no luck too, or should I use the whole can of seafoam in the bike? Thank you
If it's not running, it really doesn't matter how much seafoam you put into the tank ;-)
Old Jun 10, 2024 | 07:50 PM
kylehasyourfrenchtoast's Avatar
New on the left both don’t have expiration dates.
Old Jun 10, 2024 | 11:04 PM
dannoxyz's Avatar
At this point, too late to use Stabil. That’s what you want to put in before storage. Now it requires completely disassembling carbs down to every last bit for scrubbing and cleaning.
Old Jun 10, 2024 | 11:38 PM
is there anything could use to wash the inside of the tank out with that does not cause flash rust? Maybe Evaporust?
Old Jun 11, 2024 | 04:49 PM
dannoxyz's Avatar
nah, any bare metal will rust. Rust-removers actually just make it worse by removing rust coating and exposing bare metal below.
Phosphoric-acid works best because it leaves mildly protective phosphate coating. Can find at Home Depot as concrete stain/rust remover. Read label carefully to make sure it's 100% phosphoric acid. Best to completely fill tank with petrol immediately after rust removal.
Old Jun 13, 2024 | 12:13 PM
clippy's Avatar
flooding cylinder and gas coming out of air duct indicates clogged float that can't close
my94f2
F2 Tech
Dec 28, 2011 11:21 AM
Stiggs
Jan 19, 2010 12:00 AM
pr0jktmayhem
Nov 10, 2007 10:57 AM
fredhill032188
Jul 9, 2007 10:27 PM
fredhill032188
Jul 9, 2007 07:11 PM
