WONT START HELP!!!!
Old Nov 8, 2007 | 04:40 PM
pr0jktmayhem's Avatar
Default WONT START HELP!!!!
So i tried turning the bike on the other day and it kept cranking and cranking and not turning over. There would be a couple of loud back fires, so instead of trying to turn it on, i called it quits and decided to see if anybody else recognized this problem. Strangely the bike was running perfect a few days ago, and it hasnt been ridden since, so what could possibly have failed in that short period of time? anybody?
Old Nov 9, 2007 | 01:59 AM
SilverZZR's Avatar
Default RE: WONT START HELP!!!!
Could be valves, could be plugs, could be carbs, could be bad gas. Normally a back fire is caused by a build-up of gas or a bad fule air mixture. If the gas is building-up then it means you have little or no spark. I'd check the plugs and plug wires to start. Then check the carbs and ECU. Could be a timing problem as well ...... could be a lot of things really just gotta check it all one by one starting with the smallest thing first.
Old Nov 9, 2007 | 03:14 AM
catamayo85's Avatar
the same EXACT thing happened to me when i bought my F3, it ran perfect, i brought it home, a week later the same thing was happening, i bought a battery charger (it died while i was continually trying to start it) and i changed the spark plugs, it purred like a kitten after that...good luck!
Old Nov 10, 2007 | 10:57 AM
reaplace spark plugs./ now its starts up fine! thanks for the help
supermover25
Mar 15, 2019 08:14 PM
C Jacob W
Jul 29, 2013 11:03 AM
CTcbr929
Jul 31, 2009 12:25 PM
tagger609
Jun 27, 2008 02:09 PM
mishab
Sep 7, 2007 01:00 AM
