My Solution For Spool Mounting
Old Aug 29, 2012 | 10:37 PM
cmartino88's Avatar
Default My Solution For Spool Mounting
Unsure if anybody has done this yet but I have not seen it. Basically what I did was weld some 1/8 inch steel to some thicker spacers. I then used 1/4 inch bars and drilled and tapped the not welded bar and the spacers. Then I used an 8mm bolt on the top and the 8mm bolt included with the spools to basically make a clamp for the swing arm. I will take some pictures once I have them mounted. *Important note* Make sure you know what material your swingarm is. Mine is aluminum and when aluminum and steel meet they corrode so you have to use some electrical tape to keep the two from touching.
The swing arm is 2 3/4 inches tall and 1 1/4 inch wide. Their isnt much room between there and the sprocket so go thinner on the inside than the outside.
Old Aug 29, 2012 | 11:20 PM
colorado_steve's Avatar
pictures of the end result on the bike?
Old Aug 30, 2012 | 12:10 AM
gotcbr's Avatar
Well, I've never seen this b/f. They say that 'necessity is the mother of invention.' :-)
Why not install spool inserts or weld tabs? Would weigh less & be less obtrusive.
Old Aug 30, 2012 | 02:59 AM
cmartino88's Avatar
Well these brackets were free for me. I just used some scrap metal at my work and we have an on site weld shop. I considered the tabs but removing the swingarm and all that was the only way to get them welded on so it was too much of a hassle, and I had never heard of the inserts before...I may look into that. Besides weight doesn't concern me since I can take the whole thing off whenever I please . Pics on the bike will be added in a few hours.
Old Aug 30, 2012 | 11:03 AM
gotcbr's Avatar
No prob w/ free. ;-)
Google 'Pitbull spool inserts'.
Also check out this regarding the LP rivnut kit...
Adding Swingarm Spools to the 929
Piranha
Nov 20, 2010 03:09 PM
florida f4i
Jul 17, 2009 04:49 PM
jetjestor
Jul 9, 2008 12:06 PM
zerog_85
Sep 19, 2006 10:13 PM
city worker
Aug 5, 2006 02:58 PM
