Leaking Flued when on Choke for more that 5 Min?
Old 04-26-2008, 06:50 PM
Johny CBR's Avatar
Default Leaking Flued when on Choke for more that 5 Min?
Is this normal? Could it be that the coolant gets to hot because the bike is reving high and not moving?
Old 04-26-2008, 07:23 PM
Scrufdog's Avatar
Default RE: Leaking Flued when on Choke for more that 5 Min?
isit coolant or something else? It shouldnt leak coolant from being too hot after only a few minutes unless there are problems elsewhere. The cooling fan should kick in if its running very hot. When it starts leaking what is your temp gauge reading? Where is it leaking?
Old 04-26-2008, 07:30 PM
Johny CBR's Avatar
Temp is cool but it sounds like the fan did not kick in and some fluid started boiling? Any suggestions?
Old 04-26-2008, 09:15 PM
Scrufdog's Avatar
could be the thermostat is stuck shut...
when the bike is cold take off the coolant cap and start the bike. See if coolant is flowing or just sitting there as it warms up.
Old 04-26-2008, 09:32 PM
Johny CBR's Avatar
where is coolant cap and what should coolant be doing? Thanks for helping me out.
Old 04-26-2008, 10:54 PM
Scrufdog's Avatar
the cap is under the upper right fairing. If you take the fuse panel cover off you can see the cap. If your good, you can reach the cap and get it off of there. If the coolant is circulating you can see it actually flowing around in there a little.
Old 04-27-2008, 12:51 AM
notny41's Avatar
Why would you have your choke still on after 5 minutes?
Does it leak if you turn the choke off?
Old 04-27-2008, 09:16 AM
Johny CBR's Avatar
It does not leak with choke off. I only had the choke on for more than 5 Min for ****s and giggles. I guess your not suppose to do that?
Old 04-27-2008, 06:22 PM
cbrvroom's Avatar
well that probably caused your heat issue then.
Old 04-27-2008, 07:19 PM
kwong2001's Avatar
Well I had a problem with leaking coolant after several minutes of running and it turned out to be a leaky hose coming from the carbs. It flowed coolant through the carbs to heat them up.
The water pump doesn't start working from a cold start, it waits for the engine temps to get up first which would explain why it's not leaking right away. But yeah, could be a lot of stuff. Just pull the main lower fairings off and get a flashlight and try to spot it.
mbrown22
11-23-2010 10:37 AM
dalves11
09-22-2010 04:47 PM
Godsmackpain
07-15-2010 11:33 AM
DragonCBR
10-14-2009 12:25 PM
rino
08-12-2006 03:55 AM
Quick Reply: Leaking Flued when on Choke for more that 5 Min?
