How much choke? How much gas?
Well guys I'm 2 for 3...starting my new bike. The first 2 times I fired it right up but the temp was warm...70s.
I usually don't have too much trouble with this sort of stuff but I bought my bike for a daily commuter so I need to get good at starting it without flooding it.
Any recommendations on how much choke, how much twist on the throttle and when, when to take off some choke...are these CBR's cold blooded? The temp was in the 50's this morning.
Feel free to call me if you prefer to talk via phone....after 3pm Seattle time
Dan
206-851-5969
Dan
206-851-5969
RE: How much choke? How much gas?
Dan, I usually give it two slow twists on throttle, slide the choke to full on and hit the starter button until she fires over. It stumbles a bit and then climbs to about 2k rpms. I let it idle like that for about ten seconds and then turn the choke down to about 3/4 and let it idle for just a bit longer, about 30 seconds. Then I take off. I go about a block and then turn it all the way off.
ORIGINAL: Captain Obvious
Mine stalls almost every time on the day’s first start. I think it is because of the auto vacuum shutoff feature. I want to draw a vacuum in the line and see if it helps.
Yes It's a Honda, they are all cold blooded animals.
All of the threads in this topic are pretty much the same.
Cold start= full choke, twist throttle very slightly, push button, fires up, sputters for a split second, then gurgles to a clean sound (all this happens in about 10 seconds). Then I let it warm up about 20 secs, give it a slow twist up to about 1800 rpm, then the bike sounds very rythmic. Move choke back to half, continue to warm up for another minute, release choke, let warm up 2-3 minutes, then go.
Warm start= no choke, no throttle, wait about 1 minute, go.
same here as well. full choke and leave the right wrist out of it. No problems
however......if I have left the bike for a while (like over a week or so) then i always have to try starter twice. First time gurgles and sputters for a sec and then dies. May be just not getting the fuel through after a lengthy sit? Second attempt is no problems
also i hear you shouldn't run the starter for more than 5 seconds or so at a time. maybe someeone can elaborate whether that caution would be purely for battery life protection or whether excessive winding could damage the starter?
jas
jas
Thanks all for the advice...
I need a new battery so I didn't drive to work today (ya..that sucks) but I fired it up easily this morning. One slow, partial open and close on the throttle, full chock..blump..blump...blump...vroommmmm
I talked to the previous owner and he said no throttle at all, full choke...
The battery is low on voltage so I'll chalk the blump..blump..blump... to that. Will pick up a new battery today and I'll be good to go!
Sounds like my too...
If using the bike every day, cold start on full choke with a little right wrist, after about 15 sec down to about 3/4 and after 2 minutes taking off. As soon as changing to 2nd gear am turning the choke off and gentle on the throttle...warm start with no throttle. So far no problems with starting except for old battery that I replaced ..
