Killswitch activates on touch instead of click
Old Mar 12, 2018 | 12:01 PM
nilsNL's Avatar
Cool Killswitch activates on touch instead of click
Hi Forum,
First of all thanks for all the advice on my previous post. I've managed to sort everything out .
Today when I stopped at the gas station I wanted to turn of my bike with the killswitch. I noticed that the bike 'dies' by just touching the switch with my finger, instead of clicking/toggling the switch to the off position. I tested this a couple of times and every time I apply just the smallest amount of pressure to the switch the bike dies.
It scares me a bit because I don't want this to happen when hitting a bump in the road.
Have you guys encountered this problem before, and do you have any tips/advice on how to solve it? Is it possible to open the switch up or should I look for a new switch?
Old Mar 12, 2018 | 05:06 PM
Gunk's Avatar
Originally Posted by nilsNL
Hi Forum,
I’d just replace the whole switch
Old Mar 13, 2018 | 06:05 AM
nilsNL's Avatar
Thanks Gunk, I ordered the switch.
Would you happen to know where the switch cables plug in to? I tried looking it up in the manual but is says nothing about it. The switch ( img attached ) has some connectors. I can try to follow the old cables but perhaps you know where I can search.
Perhaps I can even just replace the top part of the switch and leave the rest on, guess i'll find out when it arrives.
new switch
Old Mar 13, 2018 | 09:16 AM
trachito's Avatar
Most likely under the tank. Just follow the wires.
The wires inside the switch are soldered on and wouldn't be worth the hassle of taking apart. Plus, there's a chance you may mess it up. You'll see how it's set up internally once you remove it.
Old Mar 13, 2018 | 10:37 AM
wes 17's Avatar
Agreed best solution to replace and not repair. Might give mine a tickle to check now. Never know ?
Leave your replacement switch intact. Your connections, should you have a like for like component, will only be the length of cable away.
If the original cable becomes part of the loom, leave it alone until you’ve proved your new switch is all good.
Some nice black insulation tape would be handy to finish the job off.
Best of luck mate
Old Mar 22, 2018 | 07:20 AM
BwanaTumbo's Avatar
Yup something has gone t!ts up in that there switch unit. Id have a look myself but if you have ordered one don't bother. Id keep the old one though as you never know. The connections are behind the front fairing if i remember correctly. Don't mod the cable it will be a nightmare! just replace the whole thing as its just plug and play!
Ill have a look when I get home and let you know where the connectors are later on.
Old Mar 22, 2018 | 04:31 PM
nilsNL's Avatar
Thanks bro!
Still need to swap the connector. Something is indeed wrong within the switch. Today I noticed the lights will flicker when I tap the switch with my finger. Hopefully it'll be easy enough to swap it. I'm a bit scared because the manual says to disconnect the throttle cable at the carbs in order to remove the switch. I rather don't and see if I can get enough free play to leave the throttle cable in the carbs.
Old Mar 23, 2018 | 09:03 AM
BwanaTumbo's Avatar
Hi nilsNL,
Yep they connect behind the fairing....... I'm sure you can get away with it without disconnecting the throttle cables. If not you have to take the airbox off too!
Don't be scared its an easy job even if you do have to remove the cable. And we are here to help out if you get in a pickle!
Old Mar 24, 2018 | 10:01 AM
nilsNL's Avatar
Hi nilsNL,
Thanks bro! Swapped it today with some help from a friend. For other people interested: By taking off the clip-on there's enough wiggle room to leave the throttle cable attached to the carbs. New switch works perfect .
Thanks!
Old Mar 26, 2018 | 09:57 AM
BwanaTumbo's Avatar
Sorted!
Sounds like you are getting there with her........
Ieathonda
Jul 3, 2015 11:59 AM
STREETFIGHTER88
Mar 2, 2010 08:15 AM
adambowersva
Jun 30, 2009 05:09 PM
oldschoolsdime92
May 3, 2009 09:15 AM
juan11cr
Feb 5, 2007 10:34 PM
