keeps killing
Old Jun 29, 2006 | 12:07 AM
psycojester's Avatar
Default keeps killing
so i am sitting at a stop light and the bike dies start it back up runs fine going to take off kill's start it again kills when ready to take off then got going alittle while later after i fueled up sitting at a light again kills. so i know it was not a gas issue i then relize the my idol was low so i turned it up alittle and did not kill so my question is where am i suppose to be in idol i was sitting at say 500 to 700 after i turned it up i now sitting at around 1500 at idol is this right or not and no i am not dropping the clutch. this happens when i just sit. rev it a couple then dies. any solutions will be helpfull thanks
Old Jun 29, 2006 | 10:51 AM
speedfreak chick's Avatar
Default RE: keeps killing
Is it all the time? Or only when your temp gets warm (more than halp way on the thermostat?)...and when you go to take off, you have to rev it WAYYYYYYYY up to get it to actually take off?
If so, then I'm going through the EXACT same thing. If I figure it out, I'll let you know.
Old Jun 30, 2006 | 12:46 AM
i have to take a look at my temp when it stall's next time. about the reving way up not really just more then normal. i will also let you know if i figure it out but most likely you will figure it out before me.
Old Jun 30, 2006 | 01:09 AM
city worker's Avatar
1500 sounds about right maybe a little higher think mine(93 f2) is about 1700 or 1800[&:]
Old Jun 30, 2006 | 03:39 AM
4nicho's Avatar
My F3 does the same thing when it's getting low on gas, so I just try and keep it somewhat full. My manual says to keep it idling between 1k-1200 rpm in neutral. 1500 seems a little high?
That Guy in Maine
May 6, 2013 01:36 PM
kksdad
Nov 1, 2011 05:46 AM
Mr.S7
Jul 26, 2009 01:50 AM
chestnut1011
Oct 29, 2008 11:21 AM
hugashe
Jun 17, 2007 05:34 PM
