I smell coolant
ok, so i tighten the hoses that i could reach, warmed up the bike and traced the smell down to the bottom of the bike. There i found the overflow hose to the resivor. the resivor is empty. could i still be burning off some coolant that leaked last year. the overflow hose was dry and i haven't take it out on long rides yet
If you haven't changed the coolant since you got the bike, this would be a good time
to do so. Remember with a used bike...if you didn't do it, it wasn't done.
Unless you're doing serious track time, or are in a really hot zone, normal anti-freeze
mixed 50-50 with distilled water is fine. Some of the 2%ers run engine ice, etc.,
which from my understanding are specially formulated for sustained high temps.
But if you aren't a specialist (like most of us), that's really not needed.
Be sure to hook a garden hose and flush the engine till it runs clear. You can get
a cheap kit, that will hook up the hose with an inline-adapter.
DO NOT discard the old anti-freeze in the drain. That makes you a bad person.
Most auto stores will accept it, if you don't have a city/town re-cycler that does.
Also, clean up any spills, glycol tastes sweet and a table-spoon or less will KILL
a cat/dog. Mop up any spills and flush the area throughly to dilute any remains.
This is an easy one and in-expensive, even with the cost of replacing a suspect
pressure-cap. Which I strongly encourage, as well.
Good luck, Ern
Good luck, Ern
finite
12-28-2006 12:49 PM
