I need help. May have bad fuel pump but not sure
Old 07-24-2012, 09:23 PM
Cj Maxwell's Avatar
Default I need help. May have bad fuel pump but not sure
Ok so I was riding with my buddy today and I was in 5th gear just cruising along and the bike seemed to kind putt a little bit and was losing power, I gave it some throttle and it just wouldnt go. Right before I came to a stop at the light, the bike died and wouldnt start again. This happened about a month ago but I try doing some stuff to it and it had been running fine. So what might the problem be? I really dont wanna take it to a shop and pay for someone to diagnose it. Help please
Old 07-25-2012, 10:49 AM
Dirtrider009's Avatar
When you turn the key to the on position, you should be able to hear it prime, kinda like a popping sound. If you dont hear that then its not working properly.
You could gravity feed it, bypass the pump and if it runs then you know your problem is the pump.
Old 07-25-2012, 04:28 PM
MadHattr059's Avatar
I would check out the r/r and charging system. When the r/r starts to fail (a common
flaw), it will heat up and then can't keep up with the power demands.
Bike stutters-loses power-dies...then it cools down-bike starts again-runs for a bit, then r/r heats up...
Here's my recommended reading...
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
Hope this helps, Ern
Old 07-25-2012, 04:50 PM
^ i forgot about that too, another common problem. Pretty cheap replacement part that can cause alot of hassle.
Kopi Ko
10-01-2019 08:29 AM
Rockshoxtora
08-12-2010 03:58 PM
Fool
F4i - Wanted
05-10-2010 02:05 PM
zblad
12-05-2008 01:14 AM
Quick Reply: I need help. May have bad fuel pump but not sure
