I need help. May have bad fuel pump but not sure
Ok so I was riding with my buddy today and I was in 5th gear just cruising along and the bike seemed to kind putt a little bit and was losing power, I gave it some throttle and it just wouldnt go. Right before I came to a stop at the light, the bike died and wouldnt start again. This happened about a month ago but I try doing some stuff to it and it had been running fine. So what might the problem be? I really dont wanna take it to a shop and pay for someone to diagnose it. Help please
I would check out the r/r and charging system. When the r/r starts to fail (a common
flaw), it will heat up and then can't keep up with the power demands.
Bike stutters-loses power-dies...then it cools down-bike starts again-runs for a bit, then r/r heats up...
Here's my recommended reading...
Charging System Diagnostics - Rectifier/Regulator Upgrade - Triumph Forum: Triumph Rat Motorcycle Forums
https://cbrforum.com/forum/f2-tech-9...-solved-27739/
Technical Resources - Resources for Electrical Systems on Motorcycles and ATVs - ElectroSport
Hope this helps, Ern
Kopi Ko
10-01-2019 08:29 AM
