I need engine help please!
Yeah i will definetely let you know how it goes, and too bad i didnt know you rebuilt your engine recently. i spent a good week trying to figure out all the dang hoses and electrical. oh well. i got it now.
I agree it's not a good idea to mix cases. Another thing, the rods and crank are matched up. Did you mix and match those? Are your timing marks Johnny on the spot? Do a leak down test to see if you have a leak some where.
My timing marks are spot on, and no i didn't mix and match my pistons/ rods. that's why it doesn't make sense that my pistons aren't coming far enough up. The rods, pistons, crankshaft, and cylinder assembly all came from the same engine.
I did a squish test and it turns out i have something like 1.4 mm of squish and i need .7ish. so my pistons are not coming up anywhere near far enough.
Can you elaborate on this "squish" test ? Maybe there is a technical term for it and I'm just not familiar with the slang terminology... IDK.
Im not sure if there is a technical term for it. basically you take a piece of solder and either set it on top of the piston or angle it in there so that it will be "squished" by the piston when it comes to the top of its stroke. The piston should squish the solder against the head. You then measure the squished end of the solder to figure out the clearance.
And are you saying that my piston not coming up far enough would not cause my engine to loose compression?
A piston not coming up high enough in a cylinder would cause lower compression. However the amount of travel you're describing is about the thickness of a fingernail. Normal compression is in the high 100's psi. I believe that your cam timing is off, possibly by 180 degrees or something. For you to have only 50 psi in your cylinders would indicate that your valves are not opening and closing at the right time. Is it possible you got the Intake and Exhaust cams mixed up with each other ? I know it's a stupid question and I'm not trying to be insulting or anything like that. But you're missing about 100 psi and that's huge.
No thats not insulting, that was my first thought as well. but both the cams are labeled and i know i have them in the right place.
Also i know the amount of travel im talking about is tiny, but when the clearance is supposed to be around .7mm and mine is at 1.47mm that is a HUGE difference. probably enough to cause a huge loss in compression.
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
98formulaLS1
Aug 24, 2009 10:04 AM
