How to Short Fuel Pump?
Well i finally pruchased the CBR manual so I feel more confident about my bike,.....I have a feeling my fuel ump is bad (not pumping enough). I saw that the manual tells you to short the fuel pump relay, then it tells yout to look to page 18-5 to see what they are talking about. When I turn to that page they are talking about replacing headlights..WTF ....it doesnt explain how to do the short on the relay.........so I think it must be a misprint or something.....
Does anyone know how to do a "short of the fuel pump" THanks!
RE: How to Short Fuel Pump?
Disconnect the fuel cut off relay on the other side of the bike. There are 3 wires on the connector. Don't jump the Black/Blue wire. Jump the other 2. Put your ignition key on. The fuel pump should flow until you put the ignition back to off.
I might be wrong on the wire color, it explains it all in the service manual, look a little further, I think it's somewhere on page 18-15, 18-16...
Thanks alot ....the fuel pump was not working properly , so I began to take off the fuel pump etc, then I decided to try it again before I took it off and the fuel pump worked perfectly......so now im back to square one. The bike is running smoother now, though I dont think is running as smooth as it should but its pretty stable. The last thing I have to check is the volts of the battery while off and while on to see if its the rectifier. Im waiting for a friend to bring a volt meter
If the rectifier is bad, is it possible that the bike's idle would be a little rough?
I let the bike run for like 20 min and it didnt turn off.... however, im not going to venture outside my house cos Im not paying no more tow trucks!
Kopi Ko
10-01-2019 08:29 AM
