How to fix my mistake?
Old Aug 11, 2019 | 11:01 AM
Skeletobor's Avatar
New Member
Default How to fix my mistake?
Howdy gang,
I got the cbr 600 as my first bike about a month ago from a guy who kept it in pristine condition. Until yesterday, I rode the bike just fine with no issues. I've been learning more about the bike since I bought it, and after reading the manual recently, I realized I've been riding the bike at a high idle, at around 3-4k. Reading some more, I saw I can adjust the idle speed with the throttle stop screw next to the fuelcock. So I did that yesterday morning, and maybe I turned it too much because now the bike will only start with full choke, and giving it some throttle, after which, it will only idle at 4k and will stall once I let off the choke.
Could someone explain what I did wrong and why its causing the problem I'm having now?
Thanks!
Old Aug 11, 2019 | 11:31 AM
There's a couple things. If you can, just reverse the **** until you get to 1,200 RPM after it's warm. The other thing is if you turned it too far out, you may have unscrewed it from the base. If that's the case you will need to pull the fairings and whatever else it takes to get to it. Mostly the tank will need to come off too. There's a small spring and washer you will need to find and reinstall. Finding them is a pain. Don't ask me how I know.
But hopefully that isn't your issue.
Old Aug 11, 2019 | 11:56 AM
Skeletobor's Avatar
New Member
Turning the **** when the bike is warmed up doesn't do anything. If I did unscrew it from the base, does that explain why it will only run with the choke on and stalls when its off?
Old Aug 12, 2019 | 12:46 PM
Yes it would
Thomas
Jul 1, 2011 08:58 PM
93MitsuVR4
Jun 7, 2011 12:57 PM
zoomman113
Aug 2, 2010 10:21 AM
viva_brasil
Apr 3, 2008 11:16 PM
jvawter81
Apr 2, 2008 03:09 PM
