Hmmm...where did these two hoses go again?
Old May 14, 2014 | 04:02 PM
SmokinJoes's Avatar
Cool Hmmm...where did these two hoses go again?
I took apart the bike after a coolant leak and discovered two hoses, on on either side of the bike, open to the atmosphere and just sort of hanging down. Not sure if these are where the coolant dripped from.
I have not yet been able to identify where these hoses are supposed to connect to. I have studied the manual, diagrams, and fiches, but still not sure.
Attached is a photo with the suspect hose circled.
Old May 14, 2014 | 05:58 PM
edwardzx7's Avatar
Looks like a f2 engine or cylinder head. F2 s have a vacuum. port right there that connects to the petcock on the fuel tank. The cbr 900 also has the same vacuum port on its petcock. hope this helps . maybe previous owner did some head work or maybe swapped out heads and tank. just a thought.
Old May 14, 2014 | 10:36 PM
SmokinJoes's Avatar
Appreciate the response!
I don't think these go to the petcock. The petcock only has 1 connection, and that's to the fuel pump. The fuel tank itself has two connections, and I know where those are as they have mounts to them.
P.S. Because I didn't get a chance to take out the air filter housing yet, I opted to grab a photo of someone else's bike online that showed the suspect hoses. Not sure if it was an F2 or an F3, but the hose set up in the photo served the purpose for this post
DanishF3
Oct 16, 2010 10:57 AM
Blue Fox
Oct 14, 2007 02:26 PM
pitsvtec
Jan 6, 2007 09:16 AM
Brando159
Aug 31, 2006 12:09 PM
zer0spacee
May 16, 2006 02:59 PM
