high beam indication light not working on clock :(
Old 01-09-2015, 02:43 PM
dodger79's Avatar
Question high beam indication light not working on clock :(
Hi guys, so the high beam indication light on the clocks isn't working. Investigating this today, the copper circuit on the reverse of the clocks for the high beam is beyond just cleaning up or a new bulb popping in.
Basically, I'm intending to wire in a very small bulb in to the relevant wiring and to put it in the hole where the stock bulb goes so the blue light on the clocks illuminates. I was hoping someone could recommend what to get and where to get it from. I'd like to do this as it may be a requirement of the UK MOT test!
I have the same issue with the bulb that illuminates the bottom of the speedometer and I think the corroded circuitry is also causing the tripometer not to function. This is what you get with living in England!
Any suggestions would be great.
Hope this makes sense
Roger
Old 01-09-2015, 06:15 PM
Conrice's Avatar
I would stick a thumb tack into your harness after the connector and put 12v to it just to be sure.
Anyways, your local autostore should have something for you.
Old 01-11-2015, 01:03 PM
dodger79's Avatar
Cheers conrice yeah that's worth doing to make sure.
Old 01-16-2015, 02:14 PM
dodger79's Avatar
Default vid of what I did today...
Just showing what I've been doing with the bike to fix the clock bulbs and the result...
Dewey0038
10-30-2009 07:35 AM
minur505
11-27-2008 06:43 PM
Rennen
09-02-2008 10:50 AM
deadboy519
10-08-2007 04:07 AM
Glocker23
03-16-2007 06:03 AM
Quick Reply: high beam indication light not working on clock :(
