Hey guys need help I'm a noob
Old Aug 5, 2012 | 04:43 PM
genesisjoelton's Avatar
New Member
Exclamation Hey guys need help I'm a noob
i have a 95 cbr.600. i just got this bike about 2 months ago in oder to start the bike we pulled it with a truck and it's starts but im trying to figure out this wiring problem. now what do i need to look for , cause it does not crank what so ever when i push the start buttom so please give me some detail.
Old Aug 5, 2012 | 06:51 PM
IanCBR600F3's Avatar
Start with the easy things. Check your fuses. Then check the battery. Use a multimeter. Should be around 12.4 volts sitting and about 14 at 4-5k rpms. Let us know after you do that
Old Aug 5, 2012 | 09:04 PM
New Member
fues good battery good bike will not start as of now cause i dont feel like pulling it with a truck so anything
Old Aug 5, 2012 | 09:08 PM
New Member
ok done that and nothing still
Old Aug 5, 2012 | 09:29 PM
you can bump start it. you dont need a truck. push it fast in 2nd gear with the clutch pulled then jump on and let go of the clutch. so what is the battery at when you rev to 4-5k rpm?
Old Aug 6, 2012 | 12:38 AM
New Member
well i have to have a truck to get it going fast enough and to do it many time to get it to warm up the but im just trying to figure how to figure out wats going on with the starter buttom or is it the wiring it self
Old Aug 6, 2012 | 06:26 AM
74demon's Avatar
Use a test light or a voltmeter to trace the power path from the battery to the starter. It will go through the start switch, kill switch, kickstand switch, and a relay. Get a diagram and figure out what is what.
Old Aug 6, 2012 | 09:52 AM
New Member
got cha thanks then if im good though all there then what and what kinda of voltage or ohms am i looking for
speeddemonx60
Feb 7, 2010 11:02 AM
Vanandt71
Jul 29, 2009 07:40 PM
3v1lj03
The Hurricane Saloon
May 1, 2009 09:59 AM
ZJcrawler45
Apr 13, 2007 08:44 PM
ninetyfivehp
Jun 26, 2006 06:35 PM
