Help With timeing Sensor. Thanks
Old Apr 29, 2008 | 04:54 PM
SilverF3's Avatar
Default Help With timeing Sensor. Thanks
I need the sensor that gos on the bottom of the block right side with the timing cover any one got any or and help ideas on what i can do, the sensor is broke so the coils wont work i just tested the coil pack and there both good. LET ME KNOW WHAT YOU GUYS THINK! Thanks
Old Apr 29, 2008 | 05:30 PM
SilverF3's Avatar
Default RE: Help With timeing Sensor. Thanks
How would i tell if thats the problem also and all my fuses are good and I was also thinking the big black box could that be bad and if so the bike wouldnt run right plz Help me.
Old Apr 30, 2008 | 06:22 AM
nrecore0223's Avatar
Its an ignition pusle generator. That was my problem with my bike. I tested the resistence of the wires at the pulse generator connector and at the main harness. Both tests showed that it was below the required spec of resistence. So i went to a dealer and bought one. Soon as i put it in she fired right up. Just in case you wanna know my bike was fireing and getting fuel. The problem was that the ignition pulse generator was telling the plugs to fire at the wrong time. So it just wouldnt run. Cost like 55 bucks to buy the part at the dealer.
Old Apr 30, 2008 | 08:05 AM
SilverF3's Avatar
Man so it was fireing then ok mine is not, Dam i have a feeling that its my black box not working not givin a job to all the senors then, thanks for the help and i will look into it more now. Thanks nrecore0223
Old Apr 30, 2008 | 10:26 PM
Scrufdog's Avatar
i have a pulse generator sitting around, only problem with it is that the plug was cut off, so you'd have to solder the old sensors plug to it.
I'll send it to you for the cost of shipping.
Old Apr 30, 2008 | 11:30 PM
zerochickenstrips's Avatar
If your sensor is broken, then it won't be picking up the signal to fire the spark plugs. Start with replacing it with a good one before you get all antsy in the pantsy to replace expensive parts.
Old May 1, 2008 | 09:30 AM
The sensor does not always "break". Mine was working and all the plugs were firing. But it still would not start. In the manual it says to test the resistence and if its below a certain amount to replace the sensor. I think the minimum resistence is like 460 ohms. Mine was at 452. Not much lower than spec. But i replaced it anyways and as soon as the new pulse generator was in, she fired right up. So this kind of proves that sensors dont always just quit on you. Sometimes, they are not fully to the spec and still work somewhat. I did no other work but replace that pulse generator. But yes i did have spark. If you do not have spark, it could be the coils.
lovinsF3
Oct 3, 2013 01:08 PM
Zero1080
Jul 15, 2009 09:17 AM
sco7tys
Mar 27, 2008 06:41 PM
seldon929rr
Mar 9, 2007 11:50 AM
rowleymatt
Feb 14, 2007 12:48 AM
