Stunters Corner For all those stunters out there.. share your knowledge, talk about it. Those that do not like stunting, please stay away. Please read disclaimer!
tip over sensor
Old Jan 29, 2007 | 11:06 AM
seldon929rr's Avatar
Default tip over sensor
does anyone know how to take the tip over sensor off of a 929?
Old Jan 29, 2007 | 01:25 PM
all8280bcc's Avatar
Default RE: tip over sensor
did you try a search i would have sworn i saw a write up on here a little while ago.
Old Jan 29, 2007 | 02:22 PM
f4istunna's Avatar
if its similar to the f4i twist the 2 outside wires (should be 3) together leave the middle cut and put a piece of tape on the end to prevent it from touching anything else.
Old Feb 14, 2007 | 10:02 PM
thesaint's Avatar
what kind of issues are u having with the tip sensor, i have stunted my 929 quite a bit, and havent had it affect it at all, just want to see what it prohibits.
Old Feb 14, 2007 | 11:59 PM
jmhIV's Avatar
Find the 3 wires that run to the sensor. there should be a green, red, and white one. On my 600rr I had to splice the white w/ the green and leave the red pulled back. If you splice the wrong ones you will now b/c it will either not turn on the fuel pump or will blow the fuse. trial and error.
If you are doing long coasters or dragging tail for a long timeit can cause your tip over sensor to kill the bike. No chainsaws w/ a tip over sensor either.
Old Feb 19, 2007 | 10:37 AM
I came pretty close to scrapin the other day and when I did the bike shutoff. came down pretty hard.
Old Feb 28, 2007 | 09:40 PM
zeke7681's Avatar
i think the tip over sensor on the 929 is under the tank and cut all three wires tape off the white and connect the red and green and u should be set
Old Mar 4, 2007 | 08:48 PM
ChanCBR's Avatar
The problems he is prob. having with it is when he does a high wheelie. I have heard (I can't do a wheelie this high yet) that the sensor can activate when attempting a BP wheelie. But Honda's sensors are real easy to disconnect. See the 3rd or 4th post. I think he has it right.
Old Mar 8, 2007 | 11:11 AM
yeah it shuts off like a governor on a car
Old Mar 9, 2007 | 11:50 AM
stuntn_r6's Avatar
I was scrapin for about two months and never had a problem with my bike shuttin off...
sly280z
Oct 18, 2012 12:34 AM
BETA
Jul 9, 2012 01:05 PM
sco7tys
Mar 27, 2008 06:41 PM
k.600f4i
Mar 21, 2008 06:12 PM
sixshooter989
Sep 27, 2007 06:51 AM
