Help Again :/
Old Sep 19, 2016 | 06:24 PM
Originally Posted by Jeeno
Okay so I got my rebuild kit and am in the process of taking everything apart to get the carbs rebuit and I see this
... what does this mean? its hard to tell in the pic but the left most hole is filled with gas.....
When you say hole, are you talking about the passage way to the cylinder? If so, that most likely means your float needle for that cylinder is stuck.
Old Sep 21, 2016 | 01:24 PM
Jeeno's Avatar
Okay got carbs rebuilt with new float needles and installed new filter and bike seems to be running good again. Nextra question is how important are the two ports on the back of the gas tank. I think one is a vacuum line and the other is the overfill line? Since I have had the bike neither of these have been hooked up.
Old Sep 21, 2016 | 02:30 PM
I would. You want your vacuum air to be cool and having the hose will help with that. Also the other is the overflow. When it's doing its job, you want the fuel on the ground, not on your engine.
Old Sep 22, 2016 | 07:35 AM
coalminer frank's Avatar
I wouldnt bother with the vacuum hose. It just lets air into the tank as the fuel decrease. I dont believe temperature would affect it since the tank is above a hot engine and out in sun warming the fuel anyway. As far as the overflow, it would drip on your shock not the engine, been there, done that. Neither one of mine are hooked up. A little water from rain and washing the bike aint gonna hurt, and just be careful and dont overflow the tank.
voodoochyl
Sep 26, 2006 02:27 PM
DaHowler34
Aug 15, 2006 03:55 PM
TwistedCBR
May 14, 2006 12:50 AM
sgwkiip
Jun 2, 2005 11:17 PM
sgwkiip
May 12, 2005 03:25 AM
