Gearing question?
Old Mar 19, 2010 | 01:19 AM
CBRmax's Avatar
Default Gearing question?
If you gear your bike up or down is there a way you can adjust your speedometer so it reads correctly? I just bought a 95 F3 that's (geared up i believe) and the speedometer reads faster than i am actually going. Is there anyway you can adjust that, or do you just have to return the sprockets to stock?
Old Mar 19, 2010 | 05:31 PM
ajzcamaro's Avatar
You can buy and install a speedohealer. It will allow you to correct the speedo from things like when you change sprockets. From what I've seen they run anywhere from $100.00 to $125.00
Old Mar 20, 2010 | 01:06 AM
spicymeowmix's Avatar
Official Welcome Crew Spicy Cat
if you don't do that approach, I would look into getting the f4i gauges and going from there.
Old Mar 20, 2010 | 01:43 AM
cbrseabee's Avatar
doesnt the f3 speedo read off the front wheel?
Old Mar 20, 2010 | 01:46 AM
CBRmax's Avatar
mine doesnt....?
Old Mar 20, 2010 | 01:47 AM
CBRmax's Avatar
what is the stock gear ration too? I know i have 43 in the rear and im not sure about the front. But i guess i dont even know what stock is?
Old Mar 20, 2010 | 06:54 AM
ajzcamaro's Avatar
Stock gearing is 15T front and 43T rear. The speedo pick up is located just above the tranny if I remember correctly.
Old Mar 20, 2010 | 07:56 AM
The F2's speedometer was gear driven off the front wheel. The F3's use a speed sensor located just to the rear of the Starter above the transmission. Since the speedometer is electronic, and not mechanical, the SpeedOHealer can adjust the displayed speed.
Incognito
Jul 20, 2009 03:05 PM
gerrit5400
Aug 10, 2008 01:15 PM
cbrsixhundredrr
Apr 25, 2008 08:11 PM
SquireSCA
Nov 8, 2006 05:27 PM
nizmo
Apr 12, 2006 11:38 PM
