Gear ratio. -1/+4 question
Old Nov 12, 2012 | 04:04 PM
derekvercher's Avatar
Default Gear ratio. -1/+4 question
Ok ive got -1/+2 now on bike. Thinking of going to a 47 tooth rear sprocket. Which would be a +4. Has anyone done this and or is this advisable. Should I expect future problems if I do?
Old Nov 12, 2012 | 05:39 PM
volcom440's Avatar
The most important question to ask is why you want the bigger rear sprocket. unless your stunting i see no use for it on a street bike, i have the same -1 +2 and i'll keep it that way. If your trying to get more acceleration i would recommend getting an aftermarket throttle tube / cable.
Old Nov 12, 2012 | 06:02 PM
MadHattr059's Avatar
Gearing Commander: Motorcycle Speed, RPM, Chain & Sprockets Calculator
+1 to Volcom, unless you want a one-trick pony.
Of course, if that's what you're looking for, you'll need to check for clearance issues.
You don't say what bike you're running with, but I'd check for chain rub/clearance.
You'll have added enough to the diameter of the rear sprocket, it's a potential issue.
Other than clearance issues, I can't think of anything, mechanically, that would
interfere with your concept.
Just watch the red-line, other-wise you might get a nasty surprise.
Ern
Old Nov 13, 2012 | 05:03 PM
What's the deal with an aftermarket throttle tube and cable
Old Nov 14, 2012 | 03:17 PM
edwardzx7's Avatar
Also i would try to find ways of dropping weight off the bike!!! Replace some metal parts with aluminum! Some!
Old Nov 14, 2012 | 04:09 PM
underground-mpyre's Avatar
Doesn't take as much effort to open your throttle wide open. You just replace your 1/4 F3 Throttle tube with a 2005 R6 1/5 throttle tube. It has a larger diameter for improved acceleration, feels like a racebike. But no Hp gains, just faster acceleration. Though I have tried to fit a 2007 R6 1/6 throttle tube with not much luck, even adjusted the cables at the carbs. Check out the link below.
https://cbrforum.com/forum/f2-tech-9...at-fix-141105/
brack25
Sep 20, 2009 11:07 AM
foxens
Jan 31, 2009 05:11 PM
Nauree
Nov 19, 2007 07:32 AM
terror
Sep 3, 2007 01:50 PM
PitbullF4i
Aug 13, 2006 11:56 AM
