gas tank
take the LH and RH tail fairings off. to do this you turn the screw that holds them on and gently pull them off. Once this is done, there are 2 bolts that hold the seat on, one on each side. Its a 12mm socket. They are right under where the passenger would sit. With those bolts removed, push the seat forward and lift up and there is the battery box. There is a cover over the battery. You will need to remove the 2 allen head bolts and there you go. Gas tank stays on though. You dont need to remove it.
SACBR
Jun 19, 2011 11:09 PM
