gas smell
Old Feb 21, 2008 | 04:23 PM
jwcummings's Avatar
Default gas smell
when running my bike smells like pure gas what's the prob?
Old Feb 21, 2008 | 04:54 PM
kwong2001's Avatar
Default RE: gas smell
Yeah, it's probably leaking gas lol...Pull the body work, run the bike and use a flashlight to try to locate the leak.
Old Feb 21, 2008 | 05:13 PM
jwcummings's Avatar
pulled everthing and checked everything. still smells
Old Feb 21, 2008 | 05:40 PM
kwong2001's Avatar
You could try just replacing all the lines that go from the tank to the carbs, that's the more simple/cheap way to do it. Anything else will most likely be expensive to fix. Shouldn't cost more than maybe $30-40 for all the hoses. Make sure everything is clamped also, matter of fact, might try replacing all the clamps while you replace the hoses.
edit: might run the bike so the carbs are full, then pull the tank and the entire airbox and run the bike and see if maybe you could spot it a little better. You should have at least several minutes before the carbs use up all the fuel in them.
Old Feb 21, 2008 | 06:51 PM
jwcummings's Avatar
thanks alot will try that think I need to replace hoses any way 10 year old bike
bdahl77
Jan 11, 2011 10:21 PM
Kat-Tee
F2 Tech
Aug 14, 2010 10:09 AM
08cbrr600
Aug 31, 2009 07:07 PM
firemanron
Nov 14, 2007 02:49 PM
traitorhound
Jan 24, 2006 11:08 PM
