Funny Sound 95 CBR 600 Any HELP GREATLY APPRECIATED!!!
Will replacing the cam chain stop the sound? No
Is the tensioner the cause of the cam chain making the sound? Yes
Will replacing the tensioner stop the sound? Yes
TROPhouse is completely correct about the OEM tensioner. It is oil actuated and provides pressure (tension) on the cam chain. When the tensioner fails it no longer keeps the right amount of pressure on the cam chain. Slack develops in the cam chain and the chattering you hear is it slapping against the guide. Replacing the cam chain will not correct the issue unless the tensioner is fixed / replaced (there is a way to jimmy the OEM tensioner but throwing a new one in is easier)
The cam chain only needs to be replaced if there is real cause (wear / failure). And it is a lot mot involved than replacing the CCT.
anyone?
wow thank you guys so much for your help, you guys have definitely welcomed me very warmly to the cbr world and i cant appreciate it more!!
everyone tells me to go with the APE tensioner. which i plan to do but does anyone have a write up with pictures on how you install this tensioner?
A bad joke at a newbie's expense
That's why I clarified about the cam chain. The OP was inexperienced with this problem. And I was concerned he'd be paying the stealership a wad of money for no reason.
I mean you're a stealership mechanic and a guy walks in saying he needs his cam chain replaced because of weird sound. Do you tell him bout the $50 fix? Prolly not
