fuel issues need help quick
Old Jul 24, 2008 | 07:56 PM
jbm0121's Avatar
Default fuel issues need help quick
ok 96 f3
the problem: bike stumbles from idle to around 7-8k sounds li k e its flooded, if you idl e the bike up to 3000 rpm it will accel just fine but anywher e under it stutters and stumbles lik e its getting too much fuel...
what we have tried: new plugs, carb cleaned several times making sure the float needle valves worked on each one and that the jets are placed back properly, new rectifiier, new gas, new fuel filters
we took the fuel pump off to take some pressure off the carbs....same thing. not entirely as bad but same crap
what would cause it to flood li ke this?
update in the middle of this...buddy called from home(i am at college)
he said idled at about 1000-1250 it picks up fine until 2500-5000 rpms is a bad spot that sputters
please help
Old Jul 25, 2008 | 10:42 AM
jbm0121's Avatar
Default RE: fuel issues need help quick
anyone?
Old Jul 25, 2008 | 11:11 AM
redzintimidator's Avatar
did you run some fishing line or similar through the idle jets??
detroitcbr
Feb 6, 2012 12:10 AM
Rockshoxtora
Aug 12, 2010 03:58 PM
96th_Malice
Sep 23, 2009 01:36 PM
94cbr600kid
Dec 15, 2008 05:44 AM
Pentaxis
Sep 26, 2006 09:39 PM
