front turn signals - wires?
RE: front turn signals - wires?
test all the wires..green goes to solid black..then i think the white striped one is the running light then the other is the blinker...its the brighter filament in the bulb that is blinkers..whichever works out that way...just mess with it til it works...lol
are the resistors required for anything else other than slowing down the rate of blinking? at any time would having to little or to much draw from the led's on the power system cause the lights / flasher relay not to function?
and what do you mean by back feed?
Damnit! Okay...replace my word "resistor" with "diode"
I didn't put them in to slow the rate, I wanted to make sure that there wouldn't be any backfeed. By that I mean...I didn't want to risk having one power feed (like the running light circut) attempting to send power thru the other feed (turn signal circut). By adding a the"Diode" before the connection of the power wires, power couldn't feed backward because the"Diode" only allows power ot go in one direction.
I doubt that it would ever happen, but since the two power wires are practically tied together, I didn't want to risk an electronic meltdown.
Lowridese
05-01-2010 01:12 AM
