front turn signal wires??
Old Oct 5, 2010 | 07:31 PM
Pinoyisme's Avatar
Default front turn signal wires??
Anyone know of a specific place or where i should look to find the front turn signal connectors that are on the bike??? I have new flush mounts coming in the mail soon so i was just wondering where these wires could be located so i know exactly where to go once i get the lights.
Old Oct 5, 2010 | 07:53 PM
Turbulenz's Avatar
Official Welcome Crew
Look for wiring that has these colors.. they are three wires per side..
Left side:
Orange
Light Blue/White
Green (ground)
Right Side:
Orange/White
Light Blue
Green (ground)
They are supposed to have a 2 pole and 1 pole connector on each side at the end of the harness and beginning of the signal lights..
hope that helps.
Old Oct 6, 2010 | 04:53 AM
Pinoyisme's Avatar
Should I look at the front of the bike?? Or like take the fearings off?? I tried looking for those colors cause I have the original turn signals still but I couldn't find them.
Old Oct 6, 2010 | 04:02 PM
Pinoyisme's Avatar
alright im having trouble finding these wires for the front turn signal, i have pics with the fairing off on my bike, can anyone point me into the right direction??? copy the pic and make arrows with paint or something telling me where to look for these little connectors for the front turn signal wires.Name:  0a4bcb00.jpg
Old Oct 6, 2010 | 04:04 PM
Turbulenz's Avatar
they wont be on the sides.. they will be in the front u nder the upper cowl above the front fender area..
Old Oct 6, 2010 | 06:51 PM
gotcbr's Avatar
Ok, took some diggin' but I found some old pics I'd taken when I was rehabing my wiring & installing new front signals (HotBodies LEDs not pictured). Sorry for the pic quality. Like I said, these are old pics but you can see what I have for wiring & where its located. The three wire groupings are bundled together on each side. Pics below...
Going to list like Turbulenz did, although my wiring is different colors than his on the left side. I have a 2000 F4 & have the following...
Left side:
Orange
Orange w/ white stripe
Green
Right side:
Blue
Blue w/ white stripe
Green
* If you want to re-install factory front signals, you'll use all three wires on each side - matching up the wiring.
* If you want to install aftermarket two-wire signals, you'll wire your front signals as two-wire signals, using just the solid colored wires on each side (like Turbulenz already mentioned). As for the stripe wire, just cut it clean & seal off, such as not to have an exposed wire to cause problems.
* If you want to install aftermarket two-wire signals *but* have them work like originals as running lights as well, use redzintimidator's how-to tutorial on how to: Convert 2 wire signals to 3 Wire Inputs here... https://cbrforum.com/forum/showthread.php?t=84998 .
Hope all of this helps you.
Old Oct 6, 2010 | 07:56 PM
Pinoyisme's Avatar
alright, figured it out but i wonder why would they hide the connectors all the way under the gauge pod?? wtf is up with that!!? lol i took the right side black cover that goes around the bottom of the gauges off and found them tucked away in there. but thanks for that info gotcbr, im gonna be lookin back on ur info tomorrow once i get off from work to finish it off.
KidOnOne
Mar 14, 2012 06:54 PM
nsrt4me
Oct 3, 2010 01:13 AM
angry slide
Jun 24, 2009 07:01 AM
tomutah87hurricane
Mar 5, 2009 10:24 AM
batmx3man
Jun 27, 2008 03:10 PM
