Little help
Old Oct 22, 2007 | 10:27 AM
isabella98f3's Avatar
Default Little help
i was working on the bike yesterday and caused a problem for myself. i had installed some flushmount lights on the front earlier but had never finished screwing it in properly. so i drilled the holes and finished it up. did the left one first, and everything was working fine. all the lights were on, and blinker was working.then i did the right one. this is where i ran into problems. one of the screws i was putting in bit through on the wires and i noticed it a little too late. i know i'm going to have to replace that whole light now. but i still put it all back together cuz it was running late and i didnt want to deal with it anymore. after putting it all back together, i turned the bike on and noticed that none of my lights work now. the only light that works in the headlight. no running lights, no brakes, no signals and no lights in the gauges. even the neutral light, oil side stand lights dont work. any clue what i might have done???? i was thinking of a the fuses but didnt check them yet. anything else????
thanks guys.
Old Oct 22, 2007 | 10:49 AM
Donohu40's Avatar
Default RE: Little help
My freind had a smiliar problem on his 03 600rr. He had turn signals that were shorting out and they would blow out the fuse which turned off all blinkers and brake lights.
Old Oct 22, 2007 | 11:39 AM
Northernfirepower's Avatar
Fuses
