Fork adjuster stuck?
Old Jan 29, 2007 | 02:22 PM
onblur's Avatar
Default Fork adjuster stuck?
I have a set of forks that don't want to adjust. Since the adjuster seems to me made of brass or some similarly soft metal, I can't just crank down on it with a screw driver. Anyone have a trick for how to free these up? If I pull the fork apart, is there a way to rotate it with something more substantial inside? Right now, I've been hitting it with pb blaster and giving it a shot every day or so.
Pete
Old Jan 29, 2007 | 03:46 PM
jbreit's Avatar
Default RE: Fork adjuster stuck?
Have you tried to rotate it the other way...? It might be in all the way. You are right thats its brass, and you can't go nuts on it, but they only rotate a few turns, clicking as they go, and they will always stick out some.
Old Jan 29, 2007 | 08:28 PM
CBR600F3ROX's Avatar
What do they adjust turning it left or right, stiffer or softer suspention?
Old Jan 29, 2007 | 08:29 PM
abadfish's Avatar
what are you considering to be the fork adjusters???
Old Jan 30, 2007 | 12:37 AM
onblur's Avatar
ORIGINAL: abadfish
I guess that wasn't worded well. I meant the rebound adjustment on the top of the forks. I think it's rebound, anyway. It's not the preload, it's the smaller brass **** that should turn with a coin or a screwdriver.
Old Jan 30, 2007 | 12:58 AM
abadfish's Avatar
so what are you saying???? that you turn preload a few times and then its stops turning??? You do realize that there is a limit to adjustability, right???
spdbump36
Aug 1, 2019 12:08 AM
ShawnR
Nov 8, 2014 11:56 AM
Judge Apocalypse
Jul 16, 2013 06:40 AM
civicblade
Apr 23, 2009 08:24 AM
R1000
Aug 11, 2006 10:40 AM
