Stuck/Broken Idle Adjuster
Old Apr 12, 2008 | 04:02 PM
spdbump36's Avatar
Default Stuck/Broken Idle Adjuster
So I tryed to adjust my idle and the screw is stuck. I tryed to wrench on it one way or another and nothing is happening. Has anyone replaced one of these or is there another way to adjust the idile.
Old Jul 31, 2019 | 09:07 PM
Punkrockhorseman's Avatar
I’m having same issue. Haven’t busted out a wrench on it yet. I’m wondering if issue is at **** end or other end. Seems should be a fairly easy hand turn. Anybody on why the **** won’t turn in either direction??
Old Jul 31, 2019 | 09:15 PM
Phil314's Avatar
The **** should turn fairly easily.
But the throttle stop on the carbs rests on the end of the screw, so try opening the throttle by twisting the hand grip just a hair and then try turning the idle ****.
If that doesn't work, you'll have to take stuff apart and see why it won't turn. It's probably something simple.
It's very unlikely that it's seized up, unless the bike was parked outside for a very long time.
Old Aug 1, 2019 | 12:08 AM
Nice thx!
So bike off open throttle a little and try turning adjust **** while throttle cracked open..?
ill try it. The bikes been garaged, seems odd won’t budge.
stevieb615
Jun 25, 2012 09:48 PM
1iwilly
Jul 28, 2010 12:12 PM
philthethrillohio
Aug 25, 2009 09:49 PM
Mako
Apr 23, 2009 08:05 AM
felk27t
Jul 27, 2007 12:25 PM
