Stuck rebound adjuster
Old Aug 10, 2006 | 05:03 PM
R1000's Avatar
Default Stuck rebound adjuster
The rebound adjuster on my rear damper is completly stuck, any ideas how to get it turnable? Could a nut be MIG-welded on it to get better turning force, or will that melt down some internal o-rings?
Old Aug 10, 2006 | 05:39 PM
TimBucTwo's Avatar
Default RE: Stuck rebound adjuster
I have heard of other members complaining about the same thing. What if you spray it down with penetrating oil, something like liquid wrench? I bet they get corroded and sand also gets in them.
Old Aug 11, 2006 | 06:40 AM
rhino94's Avatar
Please don´t think I´m rude R1000 but can you be turning the wrong screw? There is many to choose from down there :-)
Old Aug 11, 2006 | 08:51 AM
R1000's Avatar
ORIGINAL: rhino94
Possibly, the screw I'm trying to turn is near the bottom of the dampers right side and is reached thrue a hole in a bracket. The screw has a special head, or not even a head, more like a pin bolt with a cutted cross at the end.
I've also tried WD40 and oil for automatic transmission to penetrate a week without sucess []
The chassi behaves fine even though it appears to almost have no return damping, so I can just leave it as is.
Old Aug 11, 2006 | 09:09 AM
Steve_Cardiff's Avatar
If you're not riding the bike for a while and if you can get at the screw - get yourself some blu tac and build it up under the screw so you've got a little depression to fill with wd40. The screw should be submerged as much as possible in the wd and that should hopefully penetrate it.
Old Aug 11, 2006 | 10:40 AM
chesthing's Avatar
I'd look for a replacement shock sounds like the dampener is frozen.
spdbump36
Aug 1, 2019 12:08 AM
hurricane_rider
Sep 1, 2012 01:43 PM
bobmilkman
May 3, 2010 06:39 PM
civicblade
Apr 23, 2009 08:24 AM
onblur
Jan 30, 2007 12:58 AM
