Fix Choke Cable for 1997 F3
Old May 31, 2011 | 11:09 AM
atxbulldawg's Avatar
Default Fix Choke Cable for 1997 F3
Just quick info as my Choke was not responding at all, I searched the forum here and found one person say the choke cable may need to be adjusted or the choke port on the carb cleaned.
Just wanted to share how to get to the cable and what it looks like.
1. Remove Right Side Fairings
2. Remove Tank, or do as I did, unbolot the tank and have someone hold it up and out of the way.
3. Remove Airbox Cover
4. Remove Air Filter
5. Unbolt plastic section under the air filter
The CHOKE will be on the right side , there is a cable coming in, in my case the cable worked but it had some how slipped out and wasnt moving the choke port.
Once you can get this adjusted so that it moves left/right with the Choke Lever you are all set !
Hope this helps someone
If you are lucky your HAPPY GIRLFRIEND comes home to find her bike working again and awards you accordingly .. :P
EViR
Nov 21, 2012 10:15 PM
daddywilson
Mar 11, 2011 08:42 AM
87hcane
Aug 24, 2008 02:00 AM
jp_greenville13
Jul 13, 2008 01:04 AM
morpheous283
May 25, 2006 06:48 AM
