F3 problem
Old Oct 24, 2007 | 01:20 PM
HondaCbr600F3's Avatar
Default F3 problem
Ok so I think this maybe the cct but I dont know. Here is some of the problems after like 7 grand the bikes makes alot of noise and really does not want to pull vary hard. It almost feels like something is draging on the bike but when I pull the cluth in the hole bikes rolls good no rubs or anything. The bike has 25K on it and really when its not under load the bike free revs with know more noise then the dayI got it just under load its gets really winy. The only thing i can really think of is timing with the cct any in put would be nice. thanks guys.
Old Oct 24, 2007 | 02:19 PM
gixxereater's Avatar
Default RE: F3 problem
Is it in any gear? How are the chain and sprockets? It wont pull past 7k in 1st gear even or just the higher gears? Could be the cct if it's making a slapping/ticking sound at idle. Under a load almost all engine noise is amplified as it's working harder.
Old Oct 24, 2007 | 04:54 PM
The sprocket and chain are new and in good shape. Its in all gears it just will not pull after 7k and the noise is way more then ever before. LikeI said its like a brake is stuck on but I have looked at all of that to make sure its all rolloing free. As for the cct it may make some noise at low rpms but not at idle could it have just sliped and timing is off a little?
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
vietladin
Dec 25, 2007 09:48 AM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
