F3 to F4i Gauge Swap
Old Mar 17, 2009 | 01:08 PM
  #31
deja_vu0000's Avatar
Nevermind all, it was the combination of loose spade connectors and poor ground on rear turn signals.... all is good... loving the swap
Old Apr 7, 2009 | 03:12 PM
  #32
jay45608's Avatar
hey i was wondering how you hook up the speedo?? on the F3 there is a speepo cable does it go into the back of the f4i cluster?? thanks
Old Apr 7, 2009 | 03:15 PM
  #33
jay45608's Avatar
you need a new flasher relay you can get it at almost any auto store they should know what u need
Old May 1, 2009 | 03:24 PM
  #34
f3BikeR's Avatar
Exclamation
I just did this swap 10 mins ago and after about an hour of trying, I finally discovered how to use the 'FI' bulb as the kickstand indicator!! To add, it is also functional in that if you put the kickstand down in gear, it stalls!
I will post this on every forum in which I have researched and read about this swap! I have yet to find the answer that I was looking for and so I want to share this with everyone.
f3's yellow/black wire connects to f4i's white/blue wire AND NOT it's green/white wire.
I couldn't have the signal all the way to the right on because I had the left one on :P
Old Jul 1, 2009 | 10:44 PM
  #35
jacked600's Avatar
ya hey, no one answered is question... I also need to know the answer..... how does that work now that it is digital ? is there somethng else other then the cluster and the 900rr thermostat switch that I need to purchase ??
thanks
-Lee
Old Jul 6, 2009 | 09:31 AM
  #36
Hey Lee,
There is a tutorial related in this forum on how to hook up the speedo... you will have to cut on both the bike and speedo and use spade connetors. I found the mating connector to the speedo online for about $13 but only after alot of searching... it's been so long i couldnt tell you where. Aside from the Speedometer ($75-$200), you will have to purchase the temprature sensor (if you want the temp readout to work) from your local honda dealer about $45... be very weary if and when removing this as almost everyone breaks them off in the block... and then you have a $200 plus bill from the mechanic the only other thing you may need or want to look into is a "speedo healer" this will recorrect the sprocket difference between your f3 and f4i... the diff is on tooth on the front sprocket and three in the rear. If you do a sprocket conversion then you dont have to worry... FYI if your trying to do this on a F2 this speedo is not for you!
Old Jul 6, 2009 | 09:49 AM
  #37
mikemcw's Avatar
When you follow the tutorial you hook the wires together and the speedo works. No speedo cable needed.
Old Aug 11, 2009 | 10:33 PM
  #38
orangef3's Avatar
going to do my swap within the next week or so...going to the honda dealer to pick up some connectors...going to make an adapter harness so i don't have to actually cut into the stock harness....just plug it in and go...will keep everybody posted, and if there is interest i may end up doing them made to order
Old Aug 12, 2009 | 02:15 AM
  #39
daazndood's Avatar
hey guys. do you know what colors controls the backlight? my backlight has been cutting on and off lately making it impossible to see at night. and dangerous.
Old Aug 17, 2009 | 09:42 PM
  #40
Hey Daz! Don't quote me but it sounds like this might be an issue with your gaUges... I've stumbled upon this before... like i said don't quote me, just be aware that this could be the issue and by all means check your wiring connections! If you search the net enough you can find manuals for the f3 and f4i, i would e'mail them to you but my desktop isn't up!
FYI all i did this conversion and i LOVE IT! I'M ALSO AN ENGINEER AND MADE A COSTOME LASER CUT BACKER OUT OF 301 STAINLESS! DOSENT RUST AND NON MAGNETIC, THAT PERFECTLY FITS THE GAUGES AND DIRECTLY BOLTS IN... NO HASSEL! I'M SELLING MY BIKE (LOCALLY) BUT WILL PUT UP PICS SHORTLY OF MY BIKE IN GENERAL AND SWAP! IF YOUR INTERESTED ABOUT THE BACKERS MESSAGE ME... I HAVE 2 EXTRA PIECES! ASKING 100.00 plus shipping! If it's too steep dont inquire but if your going for a super nice clean look, that has down bends on the sides to cover all electical... you know what to do!
dej
