engine rattling noise
Old 09-27-2010, 08:39 PM
Michael S's Avatar
Originally Posted by DanishF3
Yeah well, i thought my cct had gone, when it was in fact exhaustgas leakage from where the exhaust pipes connect to the engineblock, made a similar noise. Found that out after i'd spent money on a new cct...
One thing that I noticed when I had a bad CCT was that the sound would go away around 4-5k rpm. I'm sure with an exhaust leak you could hear it throughout. But I've never had that problem.
Old 09-28-2010, 09:50 PM
reelfisher10's Avatar
What is the difference between the lifter set and the lifter tensioner according to this diagram?
http://fiche.ronayers.com/Index.cfm/...N_-_F3_-_95-96
Old 09-29-2010, 03:02 AM
DanishF3's Avatar
I think you want the lifter set, like this: http://zsf-motorrad.de/product/28294
Mine came with a new gasket as well! Remember that you'll be working with steel bolts in an aluminium engineblock, so treat your girl nice. Also if you want to make things easier for yourself, let the bike run warm before taking it apart. Use coppergrease for steel to steel connections, and carbongrease for steel to aluminium connections.
Good luck mate!
Old 10-13-2010, 09:01 PM
Where did you get your steel from so you could make it into that tool to wind up the tensioner? And was it really easy to take out the tensioner once you wound it up? Apparently 1.5mm aluminum wont work.
Old 10-13-2010, 11:38 PM
F3LUV's Avatar
i do dirt has a very detailed how to on replacing the tensioner. i rode with a bad one for about 6000 miles but i wouldnt do it again knowing how easy it is to replace
Old 10-14-2010, 12:53 AM
DanishF3's Avatar
I know the Honda manual and even more importantly, IdoDirt, says you need this special tool, but i seriously just used a small screwdriver to wind up the spring before removing the cct.
mass-cbrf4i
08-14-2012 09:27 AM
srbooth8
04-27-2008 03:55 PM
Trouble
04-02-2008 09:56 AM
sant201
10-30-2007 01:01 PM
1badcbrf4i
01-24-2006 07:08 PM
Quick Reply: engine rattling noise
