Engine cuts out ?
Old Aug 1, 2021 | 04:49 PM
Anthony47's Avatar
Default Engine cuts out ?
This is my first post, I’ll start by saying a big hello to everybody on the forum ! My names tony and I need abit of help, I’ve just got hold of a f3. 600. 1995. The bike has 26000 miles and full service history, and is very clean. I’ve owned it about 3 months and done about 1000 miles everything good bikes been running brilliantly but I have noticed a very very small amount of smoke form the right inspection slot of bike witch I thought might be cleaning fluids or something on headers! But went for a ride today, and after thrashing the bike for about an hour I was pulling up at the back of my garage and the bike just died, I noticed a little bit more smoke on the right inspection slot of the bike. But could not determine where the small amount of smoke was coming from. Bike started up fine straight away, battery is all good fully charged, bike runs perfectly so I checked all fluids, fan cuts on when hot and calls down the engine and cuts off, so I left the bike for an hour to call down completely and went for another ride. After about half hour the bike died again and started up perfectly again. Took off lower right faring and visually looked at all wiring and could not find anything. Any help much appreciated. Sorry for a long thread.
Old Aug 2, 2021 | 08:39 AM
Welcome. That's a nice looking bike you have there. The next time the bike does this open the fuel cap. If you hear a whooshing or sucking sound and if your bike starts up again after opening the cap it means you have a blocked breather tube line. Hopefully that is it as it is an easy fix.
Old Aug 2, 2021 | 09:20 AM
Anthony47's Avatar
Cool Engine cuts out
Thanks for your reply, I don’t think it’s the petrol cap, I’ve had that before on my motocross bike, but good shout! It’s definitely electric problem it’s when it get really hot fan cuts on then cools the bike down then I’ve noticed a small amount of smoke coming from somewhere, the right inspection slot, then bike dies but starts straight back up fine no more smoke , battery seems to be good 12; 4 volts running’s 13;5 volts so I don’t think it’s the. RR. Or bike wouldn’t charge would it? Tried looking at all wires and plugs but haven’t seen anything, I’ve got to find out where this smokes coming from and hopefully not brake down somewhere,
Old Aug 2, 2021 | 09:29 AM
Anthony47's Avatar
Does anyone think it might be a bad stator? Only seems to happen when I hammer the bike for about an hour , maybe it’s Honda gods telling me that bike near 30 years old and never been ridden like that! Very weird!
Old Aug 3, 2021 | 12:28 PM
It might very well be. Section 15 of the shop manual gives instructions on a non-invasive test to do that might help you.
Old Aug 3, 2021 | 01:19 PM
Anthony47's Avatar
Thanks for the reply waiting on a manual, thanks for the tip , all help much appreciated!
Old Aug 3, 2021 | 01:38 PM
There is a .pdf version of it in the stickies section of this forum.
Old Aug 10, 2021 | 07:41 AM
Stator is on the left side of the bike. RR is on the right. How is the Voltage on the battery when idling and at higher RPM's?
Acot03
F2 Tech
Nov 19, 2022 07:32 AM
RocknrollClown
Oct 10, 2016 03:08 PM
jimmyjames
Feb 26, 2014 05:37 PM
p0tential
Feb 15, 2008 12:19 PM
toaliosis
Jun 13, 2006 06:12 PM
