ENGINE CUT OFF
Old Aug 19, 2006 | 06:39 PM
CBRider206's Avatar
Default ENGINE CUT OFF
Today, MY BIKE STALLED ON ME FOR THE FIRST TIME.. CHECK THE GAS>good CHECK THE OIL>GOOD. I think its the infamous rectifier... how do u check the rectifier or the charging system?
Old Aug 20, 2006 | 04:34 AM
pacemaker's Avatar
Default RE: ENGINE CUT OFF
You will need a multi- meter (volt meter). Do a search on this site, as it's really an on going issue.
With my bike, I started it up fine, rolled out of garage, warmed er up. Turned it off to go inside for something, tried to start again, dead as the preverbial. charged up battery, ran fine, did a 10 mile run, parked. Went start it again about 30 minutes later, dead. Clutched ok, but ran very rough.
Their tricky, not always the same things happen, different symptoms, same result. All I can suggest, if it does turn out to be the reg. get a heavy duty one. so I won't happen again
lanceam24
F2 Tech
Feb 21, 2011 11:45 AM
knifemaker87
F2 Tech
Sep 17, 2010 09:21 AM
julius1
CBR Zone
Jan 4, 2010 11:32 PM
98formulaLS1
Aug 24, 2009 10:04 AM
Workwell
Jan 14, 2009 10:02 PM
