Electrical fault
Old Jan 30, 2019 | 03:42 AM
Pssartist's Avatar
Default Electrical fault
Morning all
I`m new to the forums so hope i`m posting this in the right place!
My CBR600F-W 98 keeps on blowing the 15amp fuse and has a loud clicking noise coming from behind the dials. I replaced the indicator relay (which i was informed would be the likely issue) but that hasn`t cured the problem. The sound has changed from a loud clicking to a loud "quacking" noise and seems to be coming from behind the rev counter/speedo.
The bike starts fine and all the lights, indicators and horn are working (until the fuse blows) but i can`t shift this noise or stop the fuse from blowing.
I disconnected the leads behind the headlight one at a time to see which one might be causing the problem, and the noise stops when i disconnect the 9 pin plug. Not sure what that controls, i just know it stops the noise when its unplugged.
Any ideas?
Old Feb 15, 2019 | 08:06 AM
Can you identify the connector in this photo?
Old Feb 24, 2019 | 01:51 AM
Pssartist's Avatar
It`s the black 9 pin plug, 3rd from left.
Been told it could be something simple like the side light bulb being blown, something i didn`t check. Will have a look next chance i get.
Old Feb 24, 2019 | 02:21 AM
CaBaRet's Avatar
Yes that 9 pin is for front lights, indicators Horn and clutch switch chances are there's a crossover and blowing fuse, try taking off the horn and see if it still happens
Old Mar 1, 2019 | 01:35 AM
Pssartist's Avatar
Solved.
Got the bike out for a proper look and found a few chaffed wires in the loom that were shorting out on the frame. All fixed and sorted.
Cheers for the help!
Old Mar 1, 2019 | 01:54 AM
CaBaRet's Avatar
Originally Posted by Pssartist
Solved.
Good Job
MaxmotoMarcos
May 24, 2012 06:45 PM
falcoholic
Aug 24, 2011 11:20 AM
Jiggle_The_Handle
Aug 30, 2009 12:57 AM
Dizzymofo
Dec 29, 2008 06:50 PM
Shakta
Aug 6, 2006 07:08 AM
