Direct Air Induction Duct and Front Stand
Old Jun 14, 2024 | 11:06 PM
kylehasyourfrenchtoast's Avatar
Default Direct Air Induction Duct and Front Stand
Has anyone had to use a front stand that connects to the lower steering stem or triple clamp mounting area? The procedure follows: 1) Remove side fairings, 2) Remove seat, 3) Lower radiator, 4) Unmount fuel tank and lift up to get access to the Air Cleaner Housing Cover to unfasten the upper Direct Air Induction, 5) Loosen bolts to Direct Air Induction Duct and wiggle out.
The next year the 99' F4 has the Direct Air Induction Duct on the sides to allow immediate access with a front stand. The 98 Suzuki GSX-600R has Direct Air Induction Duct on the side to allow immediate access with a front stand, as well a 1998 Kawasaki ZX6R, 1998 Yamaha YZF-R6, and 1998 Ducati 916. However if you have a 98 Honda CBR600F3, its the procedure above with the stand on and off. Is there a way to circumvent this? Maybe velcro the duct on or trim the area covering the steering stem? I figure just glue some used ducts and move them to the side and cut DAID? I've reversed the bolt for the gas tank and put a quick disconnect fuel line clamp to easily remove the fuel tank.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Jerome Ifill
May 24, 2016 09:06 AM
desperado
Sep 30, 2010 04:12 PM
ldv12
Jan 26, 2009 12:12 PM
eric_the_jew
Oct 10, 2008 11:12 PM
transamlt1man
Dec 7, 2005 12:33 AM
